How can ! extract all the tests within one test plan or if thats not possible how can I find the test plan field in the full csv extract?
You can build a template for a document generator to extract the information. The template needs to be done in Excel format so that you can save the result as CSV (using Excel).
Please check the documentation for Document Generator: https://docs.getxray.app/display/XRAYCLOUD/Document+Generator
You may use the Test Plan template from the store (in Docx format) as a reference to build the Excel version.
Please contact Xray Support (http://Xraysupport.getXray.app) if you need further help.
Thank you.
Rogerio Paiva [Xray Support Team]
