ZAPI - 403 Forbidden Issue with Basic Authentication
kirankanumuri June 6, 2014
Hello Experts,
I'm trying to access JIRA project using ZAPI , I'm getting the 403 forbidden error .Below is the code which fetches project list. Below is the code. Any help is highly appreciated. This is completely blocking me to integrate our test automation framework into JIRA
// TODO Auto-generated method stub
		DefaultHttpClient defaultHttpClient = new DefaultHttpClient();
		StringWriter writer = new StringWriter();
		// Define a postRequest request
		HttpPost postRequest = new HttpPost("http://jira.serverservices.com/rest/zapi/latest/util/project-list");
		// Set the content-type header
		postRequest.addHeader("content-type", "application/json");
		postRequest.addHeader("Authorization", "Basic a2thbnVtdXJpOmFsbGl*****zJA==");
		try {
			// Set the request post body
			StringEntity userEntity = new StringEntity(writer.getBuffer()
					.toString());
			postRequest.setEntity(userEntity);
			// Send the request; return the response in HttpResponse object if
			// any
			HttpResponse response = defaultHttpClient.execute(postRequest);
			// verify if any error code first
			int statusCode = response.getStatusLine().getStatusCode();
			System.out.println("Response code received is : +" + statusCode);
			BufferedReader r = new BufferedReader(new InputStreamReader(response.getEntity().getContent()));
			StringBuilder total = new StringBuilder();
			String line = null;
			while ((line = r.readLine()) != null) {
			   total.append(line);
			System.out.println(total.toString());
//			is.close();
		} finally {
			// Important: Close the connect
			defaultHttpClient.getConnectionManager().shutdown();
Kiran
ahsanakhtar April 27, 2017
Hi Guys,
i am doing configuration of Zephyr plugin into jekins but i don't understand from where to get Zephyr Base URL
Screenshot : zapi-configuration2.jpg
Henry
@ahsanakhtar if you click "?" beside Zephyr, it will tel you Zephyr Base URL is https://prod-api.zephyr4jiracloud.com/connect.
Good luck to you. I have not got it working :(
kiran kumar kanumuri July 23, 2014
Hi Avinish,
I lately realized the i should have valid ZAPI license inorder to access Zephyr plugin from API.
Installed ZAPI and every thing started working :)
Thanks everyone in this post for your prompt responses
Kiran
Vighnesh V Pai April 17, 2018
is it needs to be Trail license or Purchased license?
Joseph Van Der Wee June 24, 2014
The call to BASE_URL will not be erroring because you do not need to log in to view that page. However you do for ZAPI_URL. Are your credentials definitely correct?
If all else fails try using the HTTP request methods in my helper class.
Joseph Van Der Wee June 23, 2014
Hi Kiran,
If have uploaded a Java helper class for calling ZAPI here: https://gist.github.com/jvanderwee/4758a13dded223f51bba
Hope it can be of use.
Joe
kirankanumuri June 23, 2014
Hi Joe,
Thanks you very much for your response. I tried Helper class, But still i run into same Forbidden error.In below code I had added main method which calls the methods httpCon() and get() for both I get the same forbidden error.
If I am using ZAPI_URL then i'm getting This error. With BASE_URL, i'm able to get connection response. I'm battling with this issue from the past 1week and am completely blocked in exploring the ZAPI.
Appreciate if could throw some light on where I'm doing wrong
/** Helper class for calling ZAPI */
publicclass ZAPI {
/** Status IDs */
privatestaticfinalintZAPI_STATUS_PASS = 1;
privatestaticfinalintZAPI_STATUS_FAIL = 2;
privatestaticfinalintZAPI_STATUS_WIP = 3;
privatestaticfinalintZAPI_STATUS_BLOCKED = 4;
/** URLS */
privatestaticfinal String BASE_URL = "http://jira.allianceglobalservices.com";
privatestaticfinal String ZAPI_URL = BASE_URL + "/rest/zapi/latest/execution/topDefects";
/** JIRA credentials */
privatestaticfinal String CREDENTIALS = "kkanumuri:password";
public static void main(String[] args) {
//Below call throws Forbidden
try {
String response = httpCon(ZAPI_URL, CREDENTIALS).getResponseMessage();
System.out.println(response);
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
//Below code throws forbidden exception for ZAPI_URL
get(ZAPI_URL);
//Below code works for well Base URL
try {
String response = httpCon(BASE_URL, CREDENTIALS).getResponseMessage();
get(BASE_URL);
Avinash July 23, 2014
Hi Kiran,
Were you able to resolve this issue? Please let me know as I am also facing the same issue.
Avinash
Hi Avinish,
I got this fixed. I lately realized the i should have valid ZAPI license inorder to access Zephyr plugin from API.
Kiran
Tiago Comasseto
June 11, 2014
Hi Kiran, you may try the ZAPI Python examples with 'Basic' authorization here: http://community.yourzephyr.com/viewforum.php?f=21
Cheers
kirankanumuri June 16, 2014
Hi Tiago,
I tried as per the python example, I still get the 403 error
		URL url;
		DefaultHttpClient defaultHttpClient = null;
		try {
			String username = "kkanumuri";
			String password = "12****456$";
			String userpass = username + ":" + password;
			String basicAuth = "Basic "
					+ new String(new Base64().encode(userpass.getBytes()));
					"http://jira.allianceglobalservices.com/rest/zapi/latest/util/project-list");
			// HttpPost postRequest = new
			// HttpPost("http://getzephyr.apiary-mock.com/jira_server/rest/zapi/latest/execution");
			postRequest.addHeader("Authorization", basicAuth);
			// url = new
			// URL("http://jira.allianceglobalservices.com/rest/zapi/latest/cycle");
			// URLConnection conn = url.openConnection();
			// System.setProperty("http.proxyHost", "proxyhostname");
			// System.setProperty("http.proxyPort", "8080");
			// conn.setRequestProperty ("Authorization", basicAuth);
			// conn.setRequestProperty ("Token", Token);
			String line = null;
				total.append(line);
