I have fix versions and test cycles from 2017. Every time I want to execute a new test, I have to select from the fix version and test cycle dropdowns. I see fix versions from 2017 which is very cumbersome. Is there a way to delete/hide these old released fix versions from the dropdown?
Hi @Sukanya Kulkarni ,
In Zephyr we have option to show/hide the released/archived versions in Cycle summary page. You can do this settings by navigating to Jira settings >> Apps >> General configuration >> Versions Show Configuration >> enable/disable
Thank you !! This worked! :)
