Is it on the Zephyr product roadmap to add a UI for step by step test execution? Something as simple as a modal with the current step, next/previous buttons, and a "Create Issue" interface.
Hi Ryan,
I'm not 100 percent sure of the product feature you are requesting, so I'll outline a few things we have and don't have.
Zephyr for JIRA 1.6 offers step execution results and the ability to file defects against each step. The steps are listed in a row and you can walk down the list and mark results accordingly. As well, you can create defects at any time. Does this meet the needs you described? Or do you want something different?
Zephyr for JIRA 1.5 doesn't offer the ability to add step values, so if you are looking at ZFJ 1.5 you wouldn't see this functionality.
Kind Regards,
Chris
Thanks, that answers my question.
