allow to create an issue with empty mandatory fields
David Castro February 19, 2020
Here is the problem, in my workflow I have an initial status of "draft" where anyone can create an issue even if some information is not available, but to move into a new status of the workflow (e.g. to-do) all the required fields must be completed.
I want to create issues with empty mandatory fields but keeping mandatory in further steps of the workflow.
Pedro Felgueiras
February 19, 2020
Hi @David Castro
I think you best option is to remove the mandatory option on the field configuration and on the workflow transitions add validations to make sure the fields are filed.
please check this documentation https://confluence.atlassian.com/adminjiracloud/advanced-workflow-configuration-776636620.html
Best regards,
Pedro
David Castro March 3, 2020
thanks @Pedro Felgueiras  it worked perfectly, I used one of the validators and now it's runing fine
