analyzes temp logged time in power bi
Faten.Kutbi
Hey,
I have tried many times to analyze the tempo logged timesheet in power bi using the Alpha power bi connector but I can't find the timesheet table I founds other tables like accounts, tables.. etc.
can you help me with this
thanks in advance
Liubov Topchyi
July 27, 2022
Hello Faten @Faten.Kutbi ,
The logged time can be found in the Issue Worklogs table under the Jira Work Management tab (if you use add-on in Jira Cloud).
Please let me know if this helps.
Otherwise, please create a support ticket at our Service Portal, and we'll help you to troubleshoot.
Luba
Faten.Kutbi
many thanks it woks, but how can I know which month that they logged their time on?
Liubov Topchyi
August 2, 2022
Under the Issue Worklogs there is a field Created which indicates the date when the worklog was made. Please select this field to get the information about dates.
Luba
