are there problems with Jira right now?
Michelle Olmsted July 22, 2016
General slowness and weird toaster errors....thanks for suggestion
Nic Brough -Adaptavist-
July 22, 2016
Which one?  The ones I've got access to seem to be fine, except the one I just broke, and for Cloud installs, it looks fine at http://status.atlassian.com/
If you're having issues with your system, check with another user, and then maybe raise it at support.atlassian.com if you're both having issues getting in
