atlas-create-jira-plugin-module generated pom doesn't contain jira-tests or jira-func-tests
Mark Walle February 12, 2018
I am just getting started with plugin development in JIRA, so please forgive my ignorance on this topic.
I was following the "Generate and Examine skeleton tests" tutorial and found that the command atlas-create-jira-plugin did generate the expected skeleton structure, but that the pom.xml file did not contain the expected Product-specific Dependencies indicated in Step 3; specifically the jira-tests and jira-func-tests artifacts were not contained in my pom.xml file.
Are these deprecated dependencies that atlas-create-jira-plugin no longer adds when creating the POM, and is the tutorial therefore including outdated information? If not, why didn't atlas-create-jira-plugin work properly for me (what can I inspect to see what's going wrong here)?
Will I need to manually add those dependencies in order to proceed with the next-steps of the tutorial?
below is the POM file atlas-create-jira-plugin generated for me for reference. ATLAS Version: 6.3.7:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.example.plugins.tutorial.jira</groupId>
<artifactId>testTutorial</artifactId>
<version>1.0.0-SNAPSHOT</version>
<organization>
<name>Example Company</name>
<url>http://www.example.com/</url>
</organization>
<name>testTutorial</name>
<description>This is the com.example.plugins.tutorial.jira:testTutorial plugin for Atlassian JIRA.</description>
<packaging>atlassian-plugin</packaging>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
</dependency>
<!-- Add dependency on jira-core if you want access to JIRA implementation classes as well as the sanctioned API. -->
<!-- This is not normally recommended, but may be required eg when migrating a plugin originally developed against JIRA 4.x -->
<dependency>
<artifactId>jira-core</artifactId>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-runtime</artifactId>
<scope>runtime</scope>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<!-- Uncomment to use TestKit in your project. Details at https://bitbucket.org/atlassian/jira-testkit -->
<!-- You can read more about TestKit at https://developer.atlassian.com/display/JIRADEV/Plugin+Tutorial+-+Smarter+integration+testing+with+TestKit -->
<dependency>
<groupId>com.atlassian.jira.tests</groupId>
<artifactId>jira-testkit-client</artifactId>
<version>${testkit.version}</version>
<scope>test</scope>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>maven-jira-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
<!-- Uncomment to install TestKit backdoor in JIRA. -->
<pluginArtifacts>
<pluginArtifact>
<artifactId>jira-testkit-plugin</artifactId>
</pluginArtifact>
</pluginArtifacts>
<enableQuickReload>true</enableQuickReload>
<enableFastdev>false</enableFastdev>
<!-- See here for an explanation of default instructions: -->
<!-- https://developer.atlassian.com/docs/advanced-topics/configuration-of-instructions-in-atlassian-plugins -->
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<!-- Add package to export here -->
<Export-Package>
com.example.plugins.tutorial.jira.testTutorial.api,
</Export-Package>
<!-- Add package import here -->
<Import-Package>
org.springframework.osgi.*;resolution:="optional",
org.eclipse.gemini.blueprint.*;resolution:="optional",
</Import-Package>
<!-- Ensure plugin is spring powered -->
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<scannedDependencies>
<dependency>
<artifactId>atlassian-spring-scanner-external-jar</artifactId>
</dependency>
</scannedDependencies>
<verbose>false</verbose>
</configuration>
</plugin>
</plugins>
</build>
<properties>
<jira.version>7.6.1</jira.version>
<amps.version>6.3.14</amps.version>
<plugin.testrunner.version>1.2.3</plugin.testrunner.version>
<atlassian.spring.scanner.version>1.2.13</atlassian.spring.scanner.version>
<!-- This key is used to keep the consistency between the key in atlassian-plugin.xml and the key to generate bundle. -->
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<!-- TestKit version 6.x for JIRA 6.x -->
<testkit.version>6.3.11</testkit.version>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<maven.compiler.source>1.8</maven.compiler.source>
<maven.compiler.target>1.8</maven.compiler.target>
</properties>
</project>
Alexey Matveev
February 12, 2018
It is ok. I just checked. I also do not have the dependencies in my pom. If you need them, just add the dependencies.
Mark Walle February 13, 2018
Thanks for looking into it. I'll proceed without those. Maybe someone can update the tutorial with correct information, but I don't know where or to whom to submit that issue.
Alexey Matveev
February 13, 2018
I am also not sure to whom to submit. The problem is that many tutorials were out of date in the documentation but I noticed that recently Atlassian began to fix it. And the documentation became better.
edits.
