automation for date difference
Ivan Andrieiev
I have an automation to calculate the difference between Due date and Start date, the audit shows that it works, but the Feedback is not filled. What could be the problem?
Снимок экрана 2023-04-27 в 12.04.37.pngСнимок экрана 2023-04-27 в 12.04.50.pngСнимок экрана 2023-04-27 в 12.04.58.png
Manisha
April 27, 2023
Hi @Ivan Andrieiev
As per the screenshot, both start date and due date are same 24Apr 2023. This could be the reason.
Manisha
Ivan Andrieiev
@Manisha in other project I have 0 in result.
Like Konrad likes this
Jamie March 27, 2025
Thanks for the info.
Instead of the difference between 2 dates I needed to calculate the duration of the difference in days.
For example, if today is the start date and tomorrow is the end date, the difference calculated (using the logic in this post) is 1. But the duration is 2 days (going off the basis of start of day/end of day).
To get this logic working I used the following
{{#=}}{{issue.customfield_XXXX.diff(issue.duedate).days}} + 1{{/}}
Which seems to work a treat.
John Funk
Hi @Ivan Andrieiev
Can you share a screenshot of the audit log?
Ivan Andrieiev
@John Funk  Hi
John Funk
What type of field is Feedback? Number? Text?
Ivan Andrieiev
Text Field (single line)
Like ichrak_djebrit likes this
John Funk
use {{issue.Due date.diff(issue.Start date).days}}
Smart values are case sensitive and the field name has to be exactly the same.
Ivan Andrieiev
@John Funk
there are problems with the calculation, the field is not filled
John Funk
So you copied my code above and it still does not update the field?
If so, sub out now() for one of the dates and see if that works.
Ivan Andrieiev
two different field formats, changed different dates, but even so it turns out that the audit log says "success", but the field is not filled, maybe the problem is in the format of the fields where the dates are placed?Снимок экрана 2023-05-10 в 11.40.55.png
John Funk
My apologies for not being clearer. I meant try this:
 {{now.diff(issue.Start date).days}} and see if it populates anything. Or
 {{now.diff(issue.Due date).days}}
Ivan Andrieiev
sorry for my misunderstanding, it turns out that the rule did not work with the "Due date" option, what is the problem then?
Снимок экрана 2023-05-10 в 12.20.57.pngСнимок экрана 2023-05-10 в 12.24.39.png
John Funk
Atlassian's example uses {{issue.duedate.
Try that format again with the now option and see if that works.
And if so, try to string them together again.
Ivan Andrieiev
that's how it works, thank you very much.
{{issue.Start date.diff(issue.duedate).days}} - with this expression, it outputs non-negative numbers, if on the contrary, it counts minus, for example -2. Shouldn't it be the other way around?
Like John Funk likes this
John Funk
Not if your Start date was two days before your Due date. Which I would hope it is.  :-)
Ivan Andrieiev
understood, thanks for your help, the issue is resolved.
John Funk
Great!
