×hi team please help me set up Jira automation when a task receives the desired status - this task goes to the desired page in confluence, is it possible to do this?
Hello @Adilet Seit ,
If using a third-party app is an option for you, I suggest taking a look at our application Elements Publish.
With our app you can create Confluence pages from Jira issues using recipes.
It integrates with Automation and workflows with post-functions but it has many more features than the native solution.
Indeed, you can :
In your case, you can automatically with a post-function (for every status change) insert your task data in a Confluence page.
Let me know if you have any question!
Clara
Hi @Adilet Seit
What problem are you trying to solve? Knowing that may help the community to offer better suggestions.
And, what do you mean by "task goes to the desired page in Confluence"?
We manually transfer information in tasks to confluence, but I want to set up automation so that the information is transferred itself
Could you instead use a filter for your Confluence page's macro, and then adjust the issue fields so it will be found by the search?
