we are new to Jira and since we started using it, people made projects for every task category.
we want to lower the number of projects. so we have a better overview.
The idea is to start with the following projects and use subcategories or something else so we can still categorize sub issues. today all these items have their own project. Or is it also possible to have more board for each project?
It looks like you're structuring Jira Projects as departments and/or teams, is that correct?
Projects
If you've not already decided, you should also decide what Project types to choose.
Note: See this help page for more information on Company-managed vs Team-managed: https://support.atlassian.com/jira-software-cloud/docs/what-are-team-managed-and-company-managed-projects/
Once you've made a decision on your Project structures - there's other categorisation options you can utilise for the types of work each department does.
Issue Types
Issue Types differentiate different types of work.
A key decision will be, should...
Issue Types are used in multiple other parts of Project configuration - for example, you can have different Workflows, Screens, Field Configurations, etc per Issue Type.
See more information on this help page: https://support.atlassian.com/jira-cloud-administration/docs/what-are-issue-types/
Identification Options
If you decide to go with a common set of Issue Types (which a lot of teams do, to make it simple to report on later) - there's several other options to identify the type of work:
For more information, see:
Boards
Whilst it's technically possible to create multiple Boards for any Project type/template, it's only native behaviour for one Project type - Jira Software Company-managed Projects.
Boards in Jira Software are visualisations of Issue Search Filters - so can show one Project or multiple, or a smaller segment of Issues from within a Project, etc.
If you intend to have multiple Boards per Project, I'd recommend using the Jira Software Company-managed Project type.
See more on Boards here: https://support.atlassian.com/jira-software-cloud/docs/what-is-a-jira-software-board/
Learning
I'd recommend reviewing some of the guides/support pages to help you get you started. Atlassian's documentation is very detailed/rich, and will help you on your journey to setting up your Projects.
Check out...
Hopefully this is enough to get you started - if you have any further questions, let us know!
Ste
Hi @Dennis Celen and welcome to the Community!
It is great to see that shortly after you started using Jira you're also starting to ask yourself questions. Not only about how the tool works, but how it may best support how your company or organisation is trying to do its work. The tool(s) should support your organisation and not the other way around.
@Ste Wright has offered a ton of useful information and resources. I support every single one of those references, but would also like to add one or two additional thoughts:
There is no black or white answer or a prescription that says how you should do this. Starting to think from a team perspective is definitely going in the right direction and I sincerely hope going down that track will help you land on that sweet spot you're trying to find.
In case you do get stuck, you're in an area where typically a solution partner may be of great value. Working for one myself, I know from daily experience how they can help you bridge that gap between the way you would like to work and the capabilities of the Atlassian toolset.
Hope this helps and all the best!
