Hi i want to customize jira , can do with python jira api
For what?
There are loads of tools for customising Jira, just have a look in the marketplace. And you can write your own of course.
What do you mean by "customise" and how do you want to use python to do it?
By using Python can I add external Fields in jira for example google search button
Not directly. Jira is not written in Python, so you would need to build a Python engine into an App you can install in Jira to enable something that could start rearranging and adding to the UI.
By using that library can I create fields in jira like search button something like that
