can we Use 8443 port for configuring Jira and Confluence on SSL which are on same server?
Ravichandra_Itagi July 25, 2018
Can I use a default port 8443 for configuring SSL to both Jira and confluence which are installed in Same server?
how to do if so.
Alexis Robert
Hi @Ravichandra_Itagi,
you cannot have both applications using the same port if they're running on the same server. You should assign a different port to one of them, or have another server to run each application on it own server.
Hope this helps,
--Alexis
So I can assign different port for one of the application instead of using 8443 for both application?
Thanks alexis, Configured SSL to both applications with different ports.
