captcha problem
NevilleC January 13, 2016
Hi
I've got a problem where sometimes Active Directory users are presented with a CAPTCHA at login, but the CAPTCHA data isn't being accepted.
The only way the user is able to log in, is when I reset the failed login count.
I've seen the user type the CAPTCHA and we have both agreed what the correct entry is.
How do I troubleshoot what is going wrong?
Henning Tietgens
August 18, 2017
Oleksandr Chalyi
Daniele Aparecida da Silva
December 9, 2019
The same issue over here!
Karsten Breivik
November 25, 2019
Yup, same here...
Jonathan Soo
January 14, 2016
Hi Neville,
CAPTCHA was generated by JAVA, can you verify if you're using the supported version of JAVA for that particular version of JIRA you're using ?
Jonathan
NevilleC January 14, 2016
Hi
Thanks for the response.
We're using the following;
JIRA Version    6.4.7
Build Number    64022
Java Version    1.8.0_40
Vendor          Oracle Corporation
I understand this to be OK?
Many thanks
Nev
Jonathan Soo
January 14, 2016
You can try to upgrade java to the latest version and see if the error still persist.
Thanks, I'll try this, but can't do it straight away - I'll need to schedule some out-of-hours maintenance
Henrik Mikkelsen
Exactly the same problem here.
Java 1.8.0_51
Version6.4.11
Build Number64026
using crowd and crowd is using AD delegatged authentification.
Bas Jan Dikken
March 4, 2019
Same issue here, is there a solution already?
Ivana Simic
March 20, 2019
I'm having the same issue.
