The comment permalink highlights the comment but does not reposition the page to the anchor. Refreshing the page will then reposition to the anchor. _This is frustrating to our user community especially when referencing comments from another comment_
The problem was related to a customized search field added to the issue type used to search for legacy issue numbers. Had to add class="dont-default-focus"
Hi there,
May I know you're using which Atlassian product versions?
