×Hello
we are having currently troubles of configuring ssl for the jira links.
when importing certificate the server is not responding
Hello Andrew
thank you for your reply
the redirection entry exists in server.xml
<Connector acceptCount="100" bindOnInit="false" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25" port="8080" protocol="HTTP/1.1" redirectPort="8443" useBodyEncodingForURI="true"/>
But the servicedesk page is not redirected and is available as both 8080 port and 8443 port,
The jira core page is redirected without problems and is only available on 8443
Do you have any idea?
kind regards
Chrys
Hi Chrysovalantis,
I understand that you are trying to configure SSL for Jira, but after doing so Jira can't be started. If this is Jira 7.3.x or higher, then I believe I know the problem here.
There is an existing bug in the Jira Configuration Tool that sets the incorrect protocol for the $JIRAINSTALL/conf/server.xml file.
This problem is also documented in the 7.3 upgrade notes. That page has steps to follow to correct this problem:
To update the required protocol:
- Make sure JIRA is stopped.
- Navigate to your server.xml page at <JIRA_INSTALL>/conf/server.xml.
Locate your HTTPS connector, which will look something similar to this:
<Connector port="8443" protocol="org.apache.coyote.http11.Http11Protocol" maxHttpHeaderSize="8192" SSLEnabled="true" maxThreads="150" minSpareThreads="25" enableLookups="false" disableUploadTimeout="true" acceptCount="100" scheme="https" secure="true" clientAuth="false" sslProtocol="TLS" useBodyEncodingForURI="true" keyAlias="jira" keystoreFile="<JIRA_HOME>/jira.jks" keystorePass="changeit" keystoreType="JKS"/>
and change the protocol so that it looks more like this:
<Connector port="8443" protocol="org.apache.coyote.http11.Http11NioProtocol" maxHttpHeaderSize="8192" SSLEnabled="true" maxThreads="150" minSpareThreads="25" enableLookups="false" disableUploadTimeout="true" acceptCount="100" scheme="https" secure="true" clientAuth="false" sslProtocol="TLS" useBodyEncodingForURI="true" keyAlias="jira" keystoreFile="<JIRA_HOME>/jira.jks" keystorePass="changeit" keystoreType="JKS"/>
- Save your changes.
- Start JIRA.
Try these steps. If Jira still will not start after doing this, then we would like to see what kind of errors exist in the $JIRAINSTALL/logs/catalina.out file from this time. That should be able to tell us more about this problem.
Andy
Hello Andy
it is working now, the only problem I have is that the servicedesk module is available on both 8080 and 8443 ports.
how can I redirect the servicedesk page from 8080 to 8443.
do you have any idea?
regards
Chrys
Hi Chrys,
There are a couple of different solutions. You could completely remove the 8080 connector from the server.xml at which point no one could connect there, or you could make sure that this 8080 connector has a redirect parameter in it such as
Which in turn should redirect requests made at 8080 to 8443.
But this would apply to all requests made to 8080, not just those that pertain to Service Desk
little bit confused with this
C:\Program Files\Atlassian\JIRA\logs
C:\Program Files\Atlassian\Application Data\JIRA\log
I have two log directories but no application log
which folder=
hello
after I click on save configuration and a new dbconfig.xml is written
then on reboot the service can't be started
Thank you Chrysovalantis,
In that case we will really need to see your logs.
Please have a look at your Jira application logs that I mentioned earlier, and show us what errors are occurring while you try to reboot Jira.
Thank you!
Shannon
Hi there,
Can you let us know which step you're stuck on? I assume you're going over our Running Jira over SSL article.
Please also see if you can find any error messages in the Jira application logs and any other messages you might have seen. It will help us to see which part of the issue you're having a problem with.
Shannon
