connect a task and epic
Simon Klug
July 11, 2019
how do i connect a task and epic so if i create a task and start and end date they will automatically appear in the roadmap?
Earl McCutcheon
July 12, 2019
Hi Simon,
Working in a next-gen project adding an existing issue to an epic is done from the backlog view using the 3 dot meatball menu dropdown to the right of an issue and selecting Add to parent, like this:
This will trigger a popup allowing you to add the issue to the desired parent epic:
If the Epic does not have a defined start or end date and you have enabled the Backlog feature the roadmap will add the epic based on the child issues start and end dates:
Additional details on adding an issue to an epic can be found in the documentation at:
Earl
