Hi, I've looked at the Jira and Atlassian documentation but unfortunately I couldn't find the cost management of a project. Is there a way to estimate project cost in Jira specifically with the 'man x workdays' method?
Welcome to the Community!!
It needs add-on, you may want to start here if you are looking at better implementation
Pramodh
Hi Damla,
As far as I know Jira doesn't have features for cost management. You may want to use a plugin. I recommend to try TeamBoard TimePlanner, it provides a full features Jira lacks for cost management, resource management, time tracking, timesheets etc
Hope it helps
Tam
