where can I view my license?
currently I cannot create a project managed by company and I need to contact jira administration
Hello @Youngju_영주
If you are not an administrator of the Jira product you do not have access to get a list of the administrators.
You may be able to contact your administrators if they have enabled the Contact Administrator form. If they have you would find the link to it under the gear icon near your avatar.
If that option is not available then you will have to ask other people who use the Jira instance to see if any of them know how to contact the administrators. Some people you can try to reach are:
