Hi :)
I want to create new issue (not subtask) automatically on WF transition. Is there a free plugin to create a new issue of a specific type in a specific project (not the same) and copy fields like summary, description, screenshots and link them together?
Thank you
No coding is required with script runner, see https://jamieechlin.atlassian.net/wiki/display/GRV/Built-In+Scripts#Built-InScripts-Clonesanissueandlinks
i tried to use this post function. But when i set different project and different issue type (that doesnt have all custom fields as parent) --- it doesnt work on jira (v6.0.6#6105 :(
I will take a look at this shortly.
What should happen is the common subset of custom fields which apply to both source and target get cloned.
this was a regression, fixed in latest release: 2.1.14
wow it works. however not on my localhost, but on server :) thank you very much :)
Maybe your localhost has an old version somehow, or maybe you hacked the script and it's still in your classpath?
Anyway, no problem.
you can create your own postfunction using jira api and java or you can write postfunction using script runner plugin as @ Udo Brand suggested
Hi Peter,
What you truely need is this plugin :
https://marketplace.atlassian.com/plugins/org.swift.jira.cot
It works like a charm, but it's not free.
Best regards,
Peter
To have a complete list, let me mention JJupin (paid). However, does much more than a simple add of an issue ....
ComponentAccessor comAcc=new ComponentAccessor();
IssueManager issueManager2 = comAcc.getIssueManager();
IssueFactory issueFactory2 = comAcc.getIssueFactory();
ProjectManager projManager = comAcc.getProjectManager();
JiraAuthenticationContext authenticationContext2 = comAcc.getJiraAuthenticationContext();
IssueLinkManager issueLinkManager = comAcc.getIssueLinkManager();
MutableIssue issueObject2 = issueFactory2.getIssue();
Project projObj = projManager.getProjectObjByKey("IETTU");// you need to give the project key of the issue you want to create
issueObject2.setProjectId(projObj.getId());
issueObject2.setIssueTypeId("3");// specify the issue type id you want
issueObject2.setReporterId(authenticationContext2.getLoggedInUser().getName());
issueObject2.setSummary("[JIRA-generated] "+issue.getSummary());
issueObject2.setPriorityObject(issue.getPriorityObject());
MutableIssue myissue =issue;
try
Issue newTask = issueManager2.createIssueObject(authenticationContext2.getLoggedInUser(), issueObject2);
issue=myissue;
issueLinkManager.createIssueLink(issue.getId(),newTask.getId(),(long)10090,(long)0,authenticationContext2.getLoggedInUser()); //10011->jiraLinkType(Depends)
catch(Exception e)
e.printStackTrace();
I customized some of my code which can create a new issue and link with the current issue.
you write this as a workflow postfunction and put in the transition you want.
wow thanks. please can you help me with implementing this into jira? should i save this in some file (what file extension? .py ?) I see "Script Post-Function" choice in post functions of transition - and there i can put path to file with script. PLease what are the next steps to use this script you posted? thank you very much
This code should be written in a workflow postfunction.
https://developer.atlassian.com/display/JIRADEV/Workflow+Plugin+Modules
http://www.j-tricks.com/1/post/2010/08/workflow-post-function.html
the above links will help you to create a postfunction.
then make it as jar with the help of this document and upload the plugin by
Admin->Manage Plugins->Upload .
Hey Peter,
You can also use a plugin called Create On Transition . you can have a look at the plugin here:
no i cant, its paid. and old version creates only subtasks in the same project
Yes, you can use Exocet-Lite. See
https://marketplace.atlassian.com/plugins/com.valiantys.jira.plugins.exocet.jira-plugin-exocet
or if you like to script it you could use script runner Plugin:
https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner
