I am unable to create an issue using Rest Api of Jira, please help me , where is my probem
My url: https://aa.xxx.net/rest/api/2/issue/createmeta
here I didn't provide the actual Url for safety.
Body :
"fields": {
"project":
"key": "CHAT"
"summary": "Test Rest API",
"description": "Creating of an issue using project keys and issue type names using the REST API",
"issuetype": {
"name": "Task"
and method = "Post" and content type = application/json
Hi Koushik,
First, what is the http status that you receive when POST-ing this to Jira? This might tell you what exactly is failing. It can be that a field is required and you're not providing it or it could be that you're not authenticated.
Make sure that the user you are using to authenticate the calls has the create issue permission. You might wanna use API Tokens for basic auth. Then, please check the documentation for syntax here:
https://developer.atlassian.com/cloud/jira/platform/rest/v3/#api-api-3-issue-post
Claudiu
Hello Claudiu Lionte
I am getting the error 405 Method Not Allowed
I am using google crome advanced rest clicent, with
Method : Post
Url : https://xxx.atlassian.net/rest/api/2/issue/createmeta
Content Type : Application/Json
Authorization : [base 64 conversion of my username and password]
Json Body :
"fields": {
"project": {
"key": "DMTP"
"issuetype": {
"name": "Task"
I have permission to create Task in Jira by my login username and password. Also I have an administrator privilege.
Now please help me what should be my next step.
  @Koushik Dey Were you able to resolve issue ?
I am getting 302 error for same setup
Hi @Koushik Dey
Use the POST method and url should be https://xxx.atlassian.net/rest/api/2/issue/ not https://xxx.atlassian.net/rest/api/2/issue/createmeta
The later URL gets the data that needs to be populated at the time of creation of the issue
