custom field not showing in issue navigation when project filter is set to ALL
CV July 3, 2014
custom field not showing in issue navigation when project filter is set to ALL, though the available projects for that user is the one with custom field.
Displays correctly if project filter is set to the one available project.
Vijay Khacharia
July 3, 2014
This is normal behaviour. As the filter checks if the field is available for all projects and makes it available in issue navigator only then.
Vijay
CV July 3, 2014
Thanks Vijay,
Is there a way to remove All option for that user OR select the available projects by default??
Vijay Khacharia
July 3, 2014
I dont know of a way to do what you want. I normally use advanced filter. where i have to specify project every time i create a filter.
Vijay
