descriptions not saving in Jira?
Dinesh Baldawa
August 13, 2020
When we create a ticket with a description entered on create. everything else that was entered on create screen make it except for the description.
Prince Nyeche
August 14, 2020
Hi @Dinesh Baldawa
Most probably you have an unwanted character encoding in the description field or probably you've exceeded the limit of 32k characters.
Martin Bayer [MoroSystems, s.r.o.]
@Dinesh Baldawa are you using some Jira Apps to customize "Create Issue" screen? Can you check workflow "Create" transition and its postfunctions?
SERVER
VERSION
8.8
