difference between 'depends on' and ' is a dependent of'
Sowmya Natarajan
August 19, 2019
While linking issues, what is the difference between 'depends on' and ' is a dependent of'
3 votes
DPKJ
`Dependency` is directional link.  So if,
ISSUE-1 ----> ISSUE-2
Here,
  • ISSUE-1 depends on ISSUE-2, and
  • ISSUE-2 is a dependent of ISSUE-1.
NAYANA
It does not make sense to me. A child depends on a Parent for example. A child still is a dependent of the Parent.
What is the relationship from the direction of Parent to the child?
Like # people like this
Jack Brickey
parent --> child is done via say Task --> sub-task
linking is not the same IMO as parent --> child
In my mind when I link issue I am using like "relates to" just to show two tasks are in some manner related or "blocks" says this item blocks that item and conversely that item is blocked by this item.
with Parent --> Child (Task --> Sub-task) the Task "consists" of all of the underlying sub-tasks so that the Task isn't complete until all sub-tasks are complete.
but again regarding 'depends on' and ' is a dependent of' these are not default link types.
Steve Enriquez February 14, 2023
Jack's comment is the most correct.  Atlassian descriptions could include these default link descriptions to avoid confusion.
Jack Brickey
those don't appear to be default link values and I would say they mean the same thing. I expect someone added these so I might suggest researching that possibility and if true ask them.
Sowmya Natarajan
August 19, 2019
Thank you will look into it.
Zsofia Kope September 23, 2025
Can the language be changed: A " depends on" B therefore B "is a dependency for" A. the current language is very confusing: "dependent upon" or "is dependent upon". I think as is today needs to change.
