Hi Team,
I am trying to implement a requirement in Jira Structure to fetch EPIC issue entries where criteria matches at its feature level.
Eg:
Epic1 - EPIC-01
Feature1 - Fix Version/s: value - ABC
Epic 2 - EPIC-02
Feature2 - Fix Version/s: - XYZ
EPIC3 - EPIC-03
Feature3 - Fix Version/s: ABC
Matching criteria: Fetch all EPIC record entries where it child feature is having Fix Version/s value as ABC.
Expected Outcome:
EPIC1 issue entry
EPIC3 Issue entry
We are using Jira Prem. Please suggest how this can be achieved with Jira Structure.
Umesh
Hi @Jayadev ,
welcome to the Atlassian Community!
How exactly are your epic and feature issues connected? Is it via Epic Link field? Thank you.
@Hana Kučerová @Dima Kuzmin _ALM Works_
Linking between Feature and EPIC is done via Parent Link field:
The requirement is like below.
1. Find the list of Features where Fix Version/s: value is ABC
2. if point1 condition matches, display its EPIC and all child entries in the structure.
@Jayadev in this case please check my previous response, the steps there should do the trick (you won't even need to add the second filter).
If however something doesn't work, please contact us at support@almworks.com or via customer portal support.almworks.com. You can ask for Dima (it is me) in your ticket description, and I will look into it personally :)
Dmitrii Kuzmin
ALM Works
Hi @Jayadev ,
Dmitrii with ALM Works here.
@Hana Kučerová asked a very good question. I managed to come up with a solution no matter which link is used, but, if you like, you can reach out to us at support@almworks.com or via customer portal support.almworks.com, so we could take a closer look at your setup.
First add this Formula column:
if type="feature" and fixversion="ABC": 1
Next add a filter generator by clicking "+" icon next to "Automation" - Filter - Attribute. Select your formula, "Operator" should be set to "is true", "Filter on level" - "All levels".
At this point only epics and their matching sub-issues should be displayed. If only epics should be kept, another filter needs to be added. Its JQL should be type!="feature", "Filter on level" - "All levels".
The order of the generators should be the same as in my screenshot. Of course the insert generator's query and your extend generator may differ from mine. To move a generator just drag it by the left edge (where the dots are displayed when you hover your mouse over a generator )up/down.
Hope this helps!
Dmitrii Kuzmin
ALM Works
