error when starting JIRA.
Oleg
July 7, 2017
java.lang.NoClassDefFoundError: Could not initialize class webwork.dispatcher.GenericDispatcher
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.prepareDispatcher(JiraWebworkActionDispatcher.java:205) [classes/:?]
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:142) [classes/:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) [servlet-api.jar:?]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230) [catalina.jar:8.5.6]
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) [catalina.jar:8.5.6]
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) [tomcat-websocket.jar:8.5.6]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) [catalina.jar:8.5.6]
at com.atlassian.jira.web.filters.JiraLastFilter.lambda$doFilter$0(JiraLastFilter.java:39) [classes/:?]
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74) [classes/:?]
at com.atlassian.jira.web.filters.JiraLastFilter.doFilter(JiraLastFilter.java:36) [classes/:?]
Branden McElveen July 7, 2017
Hi Oleg,
Without knowing what version of JIRA you're running, from the stack trace you provided it appears you may be running into the bug reported in JRASERVER-62486
Please take a look at the JRASERVER-62486 and review the description and the work around and see if that is the solution for this issue.  If so please vote on JRASERVER-62486 and you'll be notified when there are any changes to JRASERVER-62486.
Branden
Petter Gonçalves
September 15, 2020
Updated answer, September 2020
Besides the bug mentioned by @Branden McElveen (JRASERVER-62486), another possible cause for the error above would be the conflicting system JAVA.
To properly diagnose and work around this problem, you can follow the details of the documentation below:
Cannot start JIRA after fresh installation, 500 error page
