Hi guys,
I need help, how to download all attachments form the Issues in the project.
I can't install Bulk and to do it manual it's gonna take long time, because there is a lot of issues.
The attachemnts are stored in a folder structure in Jira_home according to ticket keys. I need to keep the structure with the ticket keys.
Please any suggestion is welcomed.
Regards
Of course always you can try one of the apps in Atlassian Market Place by searching
Attachments Manager .
Is it okay like this, because am getting error, i can't add the filter.
Please do not attempt to add a filter, just implement it and just use the JQL box to write the query directly, do not copy and past.
If you want to get the info and the fields of the issues, you can use "Export issues" button on the top right always.
Above is the MS-SQL script I'm using to get the issues containing attachments.
You get the IssueID, Issuekey, Status, Path, Filename and the size in Mb. The lines starting with dashes are optional filters and sortings to get on top of the attachments.
Hi Nenad,
For some reason my posted answer is wiped.
It describes the way how to retrieve filenames and locations on a project basis. I'll post it under this message, in the hope that it won't be deleted as malicious code.
Hi Dick,
I faced the similar issue and solved it by copying the text from Notepad and then pasting it to this area :)
