Copy and pasting URL not working in Jira Server issue comment due to text formatting
Tim Menke
Running Jira Software 7.13.3
When I'm adding comments to a Jira issue, and I want to link to an external url, I'm always fighting the interface and I'm not sure if this is a bug or if I'm just missing something.
Steps
  1. I select some text in my comment that I want to be the link to the external url
  2. Select the external link button.
  3. I will see the following:  [<text I've selected>|http://example.com]
  4. I replace http://example.com with the url I wish to go to.
  5. when I submit the comment,  I still see the exact same [<text I've selected>|<url I pasted in>]
  6. now if I go into edit the comment, and switch over to text mode,  I see an extra set of brackets surrounding the URL, and once I delete out the extra set of brackets and submit, then it works fine.
  7. This seems to have something to do with the content of the URL, because if I leave in the http://example.com and I hit submit, the link works, but I don't see any special characters or weird formatting in the url I'm using.    In this particular case, I'm just linking to an HP forum post.
is this a bug? or am I just missing something?  Thanks!
Post a new question
9 votes
Arjun Ashok Kumar Nair
July 28, 2020
I think I found the solution to this.
When you copy and paste(cmd+v) it considers the url as a link. When I pasted it as text(cmd + shift + v), the hyperlink now works
Manish Patel
August 14, 2020
This worked like a charm -- thanks
jeremypcleung
March 12, 2021
This worked perfectly!
Alex Janes
THANK YOU! This was just driving me mad.
Vijai Vj
May 14, 2021
Wow ,, excellent
it worked like a rock solid :)
Tim Menke
issue continues to exist in 7.13.12
Georgios Melissopoulos
August 12, 2019
Yes. This might be a bug. I have the same experience. Wondering why no one from Atlassian team answered this question.
Viktor
Happens here too
Tim Menke
just as an update.  issue still exists in 7.13.8
John Schram April 21, 2021
The url detection seems a little flawed still in v8.5.2 when saving.
If I paste the url the interface correctly detects it and allows me to enter a human readable version, however on save it reverts to the Markdown string representation.
Going into text mode doesn't fix it. The url I'm pasting contains a pair of [] (amongst other valid url characters) and therefore it always reverts back to the plain text version regardless of what I do.
The url is from new relic and I've included a version below. To protect privacy the url has purposely been broken.
https://one.newrelic.com/launcher/dashboards.launcher?pane=eyJuZXJkbGV0YXNoYm9hcmRzLmxpc3QOiJWSVoiLCJlbnRpdHlUeXBlIjoiREFTSEJPQVJEIn0=&overlay=eyJuZXJkbGV0SWQiOiJXRhLWV4cGxvcmF0aW9uLmRhdGEtZXhwbG9yZXIiLCJpbml0aWFsQWN0aXZlSW50ZXJmYWNlIjoiuaXRpYWxBY2NvdW50SWQiOjE5NjIwMjEsImluaXRpYWxOcnFsVmFsdWUiOiIiLCJpbml0aWFsUXVlcmllcyI6W3siYWNjb3VudElkIjoxOTYyMDIxLCJucnFsIjoiU0VMRUNUIHN1bShzYW1wbGVzX2NvdW50KSBBUyAnQVVUYXggU3VibWlzc2lvbiBGYWlsdXJlcycgRlJPTSB4ZXJvX3N0YXRzZF9wZW9wbGUgIFdIRVJFIG1ldHJpY19uYW1lID0gJ3...
Eric
August 19, 2020
This issue is not solved as of Jira 8.5.0, part of a company installation which I'm currently using.
As the original post above states, you have to go into text mode, delete the extra brackets around the url, and then submit before the hyperlinked text displays properly in the comment.
Afaan Naqvi
April 30, 2020
Wow.. thanks for sharing the solution @Tim Menke
Can't believe this is the workaround I have been looking for and will have to resort to going forward.
Viktor
Fixed: https://jira.atlassian.com/browse/JSDSERVER-6545
Fix Version/s: 4.5.0, 4.4.2
Issue Summary
Sharing a link from "Related knowledgebase articles" panel creates a comment with an incorrectly formatted link.
Specifically, the hostname is missing which causes the formatting to break.
Andrew Januszak
Did anyone submit a bug report for this yet?
Viktor
Supposed to be fixed in 8.5, have yet to try it out.
Andrew Januszak
I think that's a different issue... That bug relates specifically to Confluence linking.
Post a new question
