field with more than 200 values, issue to see all the value in modification
PARISATO Marie-Hélène
I have a field with more than 200 value (244) , if Iwant to update the value, the begin of the list is blanked , i can see only from 121 to 244, not the 120 first of the list
Hannes Obweger - JXL for Jira
Hi @PARISATO Marie-Hélène
any chance you could provide us with a screenshot or screen recording of what you're seeing?
Hannes
Dinakaran R August 5, 2025
UI display limitation in Jira custom fields—most likely a Select List (single choice/multiple choice) or Labels field with too many options (in your case, 244 values), and the first 120 values are not visible or selectable when trying to edit the field.
c'est un bug et un ticket existe déjà sur ce bug avec le navigateur Edge.
