filter project, key, and component
JT
July 14, 2013
I have a user looking to generate a filter that will list all projects in a category along with their project key and components.
Is there any way to do this via the GUI in JIRA 6.x?
Jobin Kuruvilla [Adaptavist]
July 14, 2013
Filters are for issues, not for projects.
You can display all the projects in a category but to display them along with components etc, you will need to create a custom report. Some development involved unless you can find some plugins from marketplace doing this already.
JT
July 14, 2013
Thanks for the conformation Jobin.
That is exactly what I told my user.
