Hello i am new on jira. I am writring post function in jython with jira scripting suite.
https://docs.atlassian.com/jira/6.2.7/com/atlassian/jira/issue/IssueManager.html
what kind input should i use for updateIssue method. is there any example code ?
please find a lot of examples regarding your topic here https://developer.atlassian.com/display/JIRADEV/Creating+and+Editing+an+Issue ( they are all in java)
Also please note that there is more modern way to create / update issues https://developer.atlassian.com/display/JIRADEV/Performing+Issue+Operations
If you are new - please better follow last tutorial - previous one can be marked as depricated soon
As for the first parameter - it is user that executes the update. You can get the user using UserUtil class.
