Hello, I recently installed Jira 8.2.0 on a RHEL8 server and I'm with issues about gadgets on System Dashboard.
It appears to be an widespread problem:
https://community.atlassian.com/t5/Jira-Software-questions/gadget-common-error-500/qaq-p/1007783
I gone through all those topics and tried everything, even mimicking configurations, but I wasn't able to solve this issue by myself.
So I'm here for help.
Here's my configurations:
/opt/atlassian/jira/conf/server.xml
<Connector port="8080" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^\`"<>"
maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" secure="true" scheme="https"
proxyName="jira.domain.tld" proxyPort="443"/>
/etc/nginx/conf.d/jira.local.domain.tld.conf
upstream jira {
server 127.0.0.1:8080 fail_timeout=0;
# redirect HTTP and handle let's encrypt requests
server {
listen 80;
listen [::]:80;
server_name jira.local.domain.tld
jira.domain.tld
www.jira.local.domain.tld
www.jira.domain.tld;
# handle letsencrypt domain validation
location ~ /.well-known {
allow all;
# send everything else to HTTPS
location / {
return 301 https://jira.domain.tld;
# listen on HTTP2/SSL
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name jira.domain.tld;
root /opt/atlassian/jira;
# snakeoil certificates
ssl_certificate /etc/nginx/ssl/jira.crt;
ssl_certificate_key /etc/nginx/ssl/jira.key;
location / {
# allow uploads up to 10MB
client_max_body_size 10m;
# set proxy headers for cloudflare/jira
proxy_set_header Host $host:$server_port;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
# hand the request off to jira
proxy_pass http://jira;
I tried adding the web certificates to the keystore located on /opt/atlassian/jira/jre/lib/security/cacerts and it doesn't solved the issue too.
ca, May 23, 2019, PrivateKeyEntry,
Certificate fingerprint (SHA1): C2:49:32:92:BE:7F:C3:18:FB:C9:4E:22:86:F8:B8:19:E1:26:88:B4
jira, May 23, 2019, PrivateKeyEntry,
Certificate fingerprint (SHA1): D2:DD:06:71:A1:9A:B3:5E:46:3B:8C:79:F7:A7:40:EA:F7:F2:4F:EA
And yes, my base URL is set to: https://jira.domain.tld.
Thanks for your help.
I solved this changing the JRE to the system JRE instead of the shipped JRE. Everything worked flawlessly after the change.
Hello Vinícius!
I did not understand the change you made. Do you have any step-by-step instructions?
I have exactly the same config and problem. Has anyone managed to solve it? I'm using F5 to avoid loading the certificate into the Jira application.
Hi! I have exactly the same config and problem...
@Polybio FernandesDid the guide solve your problem? After upgrading I am having the same issue. :( Other than that, Jira does work flawless. Just having that gadget URL error.
Hello!
This may be because the update has replaced the "server.xml" file for the default settings.
Mine resolved as follows:
For SSH, enter the / opt / atlassian / jira / conf folder
# vi server.xml
1) Comment all jira configuration block DEFAULT:
2) Enable the HTTPS block settings as example remembering to enter the domain name of your certificate that is in F5 in the "proxy name".
HTTPS - Proxying Jira via Apache or Nginx over HTTPS
If you're proxying traffic to Jira over HTTPS, uncomment the below connector and comment out the others.
Ensure the proxyName and proxyPort are updated with the appropriate information if necessary as per the docs.
See the following for more information:
Apache - https://confluence.atlassian.com/x/PTT3MQ
nginx - https://confluence.atlassian.com/x/DAFmGQ
acceptCount="100" disableUploadTimeout="true" bindOnInit="true" secure="true" scheme="https"
proxyName="jira.domain.com" proxyPort="443"/>
