groovy script workflow condition for project ID in Jira
David Mallon May 1, 2014
Hi, I need to make a condition in Jira workflow so that a transition is allowed only if a jira ticket is in a particular project, the project key would be ES
I am trying to do this with groovy but cannot get it going.
Any help would be graetly apreciated.
3 votes
Boris Georgiev [Appfire]
May 1, 2014
Here's the code:
issue.getProjectObject().getKey() == 'ES'
Ritu Garg October 9, 2014
Its not working for me. I am trying to in POST function to Set Field Value to constant value with Conditional execution. code is : if(issue.get("projectKey")=="BO") return true; } else { return false; } Please help to solve this problem.
Also tried : if(issue.getProjectObject().getKey() == 'BO') return true; } else { return false; }
Sascha Lang April 22, 2021
The code from Boris works for me. Thanks a lot @Boris Georgiev [Appfire]
webspin May 8, 2014
Hi Boris, thank you so much, it works great. Lucky to have people like you around
David M
Amy Bell
Can someone post what the final script would look like then?  Sorry, I didn't follow the "simple scripted condition" fix.  Thanks.
webspin May 7, 2014
Hi, thanks, I tried that and got te error below
Errors
  • NoViableAltException(8@[478:1: operator returns [Operator operator] : ( EQUALS | NOT_EQUALS | LIKE | NOT_LIKE | LT | GT | LTEQ | GTEQ | IN | IS NOT | IS | NOT IN | WAS | WAS NOT | WAS IN | WAS NOT IN | CHANGED );])
Script workflow function : The action will be allowed if the issue matches the JQL query: "issue.getProjectObject().getKey() == 'ES'"
May 7, 2014
It seems you're using the wrong condition. You should use simple scripted condition.
Like Michael_Lazar likes this
