having issue connecting JIRA to crucible/fisheye
dns
April 23, 2014
I am having this issue from crucible/fisheye:
https://www.dropbox.com/s/luy95vu3g4x3qfr/Screenshot%202014-04-23%2016.00.12.png
i have configured everything in outgoing and incoming auth from crucible/fisheye admin. copy & paste the screenshot link.. clicking it won't work
CelsoA
April 27, 2014
Ho Hachiko,
I could see the image after copy/paste. :)
Which versions are FishEye and JIRA?
Also, does the user in Crucible has permission to see this issue in JIRA?
Please open a ticket for FishEye in http://support.atlassian.comand add there 2 support.zip files, one from JIRA and other from FishEye.
Celso Yoshioka
CelsoA
April 25, 2014
Hi Hachiko,
The image link is broken.
If you are connecting FishEye/Crucible with JIRA On Demand the local instance should be running under ports 80 or 443 with valid certificate.
Could you please paste the error that you are facing here as text?
Celso Yoshioka
dns
April 25, 2014
please copy and paste the screenshot link manually. it works.
