help with creating custom fields in form
If you're open to Marketplace add-ons, Dynamic Forms for Jira (developed by the company I work for) allows you to create smart, interactive forms with conditional fields (for example, you can show extra fields based on request type or other inputs). Here's a link to the app's Support Center , where you can find a demo and more information :)
If you're looking to create custom fields in your forms, the Smart Forms for Jira app can help you go beyond the limitations of built-in Jira forms. It allows you to:
✅ Create fully customizable forms from scratch
✅ Add various field types like text, checkboxes, dropdowns, attachments, dates, and more
✅ Map your form fields to Jira custom fields
✅ Automatically populate Jira issues based on form submissions
Here's how to get started:
Open the Smart Forms builder
Drag and drop the elements you need (like Single-Line Text, Multi-Choice, etc.)
Configure each field (set labels, make it required, or add default values)
Use the Create New Issue or Update Existing Issue feature to map form fields to Jira fields
Share the form internally, externally, or embed it into Confluence or websites
📌 Bonus: You can also pre-fill values for the user and use conditional logic to make your form more dynamic.
If you're interested, you can check out Smart Forms for Jira on the Atlassian Marketplace.
Let me know if you need help getting started!
Hey Emma - Welcome to the Atlassian Community!
Can you provide some more information please? Is this a team managed or company managed project? What specifically are you needing help with in the creation process?
