when I create an issue and enter some text (e.g. upgrade) in summary field within Atlassian support, some issues related to "upgrade" then display on the screen.
How can I make this happen in our JIRA? Our jira (5.1.8) does not search and display any related issues when users enter text in Summary field. This function can remind users that similar issues existed and also the solution may be there too. Thanks
Or use this plugin https://marketplace.atlassian.com/plugins/com.suggestimate
Hi, maybe you guys still need the solution for your problem.. Here is what I found:
https://marketplace.atlassian.com/plugins/com.deniz.jira.similarissues
FYI: I dont work for them, I just think that those plugin is awesome and of course very helpful
Hariz
Hi Sherry,
That is actually from a custom script that is added to the Summary field's description. We call this script "Virgil", which can be found/downloaded from here:
You can also get more information about how we use JIRA for support here:
thanks, David.
Do I just copy the xml script and paste to the Summary field's description?
Thanks for your help.
Just ran a quick test, it seems that this may no longer work with the latest versions of JIRA. So this article is indeed outdated. In this case, it may be easier to follow @Renjith's suggestion with the plugin.
