Here is my kanban board in which I have added two custom columns "development done" and "Review".
when someone transitions an issue from Development done to Review, it is automatically assigned to a member.
what I want is that if the review is not good and we have to send our issue to previous columns in the workflow, so on transition the assignee of the issue should be automatically set to the member who was working on it before Review.
For example - suppose "z" was working on an issue that he pulled from selected for development. then he pushed the issue to Development Done and Reviewer "x" pulled the issue from development done. now x provided a bad review and decided to put the issue under selected for development column again.
I want to automate the assignment of issue to z i.e the one who was working on it before.
is that possible? if yes how?
Use two automations:
Works for me.Thank You .
