how do I break out tech debt stories in Jira velocity report
Chris Theisen
February 7, 2025
I want to show the type of story in the velocity report
2 accepted
Alexey Pavlenko _App Developer_
Hi @Chris Theisen ,
Is this what you need?
You can write any custom JQL metrics here, including the ones considering the type of a story.
I am the developer of this app - Multi-team Scrum Metrics & Retrospective.
Best regards,
Alexey
Bill Sheboy
February 7, 2025
Hi @Chris Theisen -- Welcome to the Atlassian Community!
Short answer: that is not possible with the built-in Sprint Velocity report.
Assuming you have an issue type (or some field indicator) to identify such issues, you could investigate marketplace gadgets to add to a Jira Dashboard for such reporting.
I recommend checking with your Jira Site Admin to learn if you already have such addons to use.
Chris Theisen
February 7, 2025
Thanks Bill- I will create a view for the breakout
Bill Sheboy
February 7, 2025
By the way...my suggestion was based on you needing this information often.
If you need this one time (e.g., for an upcoming report, retrospective, etc.) you could also export the issues and do a quick chart / pivot table chart in a spreadsheet to show stacked bar charts for several sprints.
