how do I integrate JIRA with ARIS
Sunil Pariwan February 21, 2022
I am trying to integrate JIRA with ARIS BPM tool
2 accepted
Nic Brough -Adaptavist-
February 21, 2022
This depends on what you want from the "integration", define that first, then we can tell you how to get started with it.  (Or maybe check the marketplace for something that can do it for you)
Wanted to integrate JIRA nd pull out the projects list, stories, tasks. etc and create those in ARIS BPM tool by using objects and updating their attributes with the details.
I have a trial version JIRA and how can i call JIRA REST APIs in java code to get the project list, stories, tasks, etc. It would be great if you could share a sample Java code where JIRA rest apis is used to pull the data.
Julia Shcherbyna _SaaSJet_
Hi @Sunil Pariwan ! As an alternative, try to use an add-on BPM (Business Process Manager) from Atlassian Marketplace, developed by my team.
Here is an online demo of the plugin.
Some features:
  • create a template, based on steps need to finish the process;
  • add instructions, checklists, form need to submit, assignee and project to each step;
  • run the process based on a template by one click once you need;
  • monitor progress of all active processes.
Florian Bauer
February 14, 2023
Hey @Sunil Pariwan
ARIS is usually used to sketch EPC or BPMN diagrams.
Flower - Process Automation for Jira allows you to import BPMN models from ARIS and visa versa. Then continue editing in a visual BPMN designer (similar to ARIS).
If you want to model your processes and automate those additionally in Jira, Flower is your perfect addon.
