how do we create a project on JIRA?
Gaurishankar Yesu
April 10, 2018
We are trying to create a project on JIRA, need help in doing so
We have admin access but not sure if that would suffice in creating projects and then create EPICS for each ISBN
Marcos Sanchez
April 10, 2018
To create a project, you have to deploy "Projects" on top and click on "Create Project". Then you can select the project type, the name, the key and the leader.
If you can't do this, then you don't have permission enough and should contact your JIRA instance administrator.
Marcos
Deleted user April 10, 2018
Hi @Gaurishankar Yesu,
As long as you have the correct permissions you should be able to create a project in the Projects section of JIRA.
Try following the documentation to create a project.
Hope this helps
