how does jira know what an unresolved issue is?
Flavius Nopcea
If I am using a custom workflow with my special workflow transitions and statuses how does jira know what an unresolved issue is so that it can display statistics for projects?
I am very curious!
Thanks you
J Thomas
May 27, 2012
Resolution is empty = unresolved
Flavius Nopcea
yeah, you are totally right...thanks!
Ramiro Pointis
May 27, 2012
Remember to mark the answer as correct flavius.
Flavius Nopcea
ok, thanks! done :)
