how i can get issue fields value using C#
am_dev
February 27, 2014
in my jira i was add a custom field (text field) in issue ..and i want retrieve this field value (what i write in text field ) using c#
thx for help
Tarun Sapra
You can query JIRA using REST APIs, using a c# REST client to do that or a normal http call that can handle JSON response -
https://developer.atlassian.com/display/JIRADEV/JIRA+REST+API+Example+-+Query+issues
am_dev
February 27, 2014
thx for replay ..
i want get a value field using c# ..for exemple in issue i added a text field called SERVER, in this text field i will write path of server ...now i want retrieve this value (path of server ) lik a string value for i can use it in my c# proram
thx
Nic Brough -Adaptavist-
February 27, 2014
You should issue a REST call to Jira in your c# program. Tarun has given the links to the examples of what your c# code needs to do.
