how often does JIRA auto backup?
Nguyen Tran
March 19, 2017
I want to know how often does JIRA backup using the auto backup feature. I had a system crash once in the middle of a workday and when I tried restoring data using my backup. I lost all of my data from that morning.
Also, how fast/slow is the backup?
Rafael Corredor
You can check your current configuration in: /secure/admin/ViewServices!default.jspa
It allows different options, even a backup every 15 minutes!!!
A backup only takes a few minutes (in a "standard"/not huge instance).
Obviously, you should take into consideration the space used for each backup file, and possible slow performance during backup process.
Nguyen Tran
March 21, 2017
What would be considered a "standard" instance?
Rafael Corredor
Something between Mid-scale and Large-scale: https://confluence.atlassian.com/enterprise/jira-sizing-guide-461504623.html
Anyway, my recommendation is to test backup process in your instance to have accurate times.
