I have built a plan and I'm looking to build a build a Big Plan
Hi @Vince Libonati ,
Can you please provide more details? Are you building a plan using Advanced Roadmaps? If so, these documents may help. For Cloud:
https://confluence.atlassian.com/advancedroadmapscloud
For Data Center/Server:
https://confluence.atlassian.com/jiraportfolioserver/what-is-a-plan-952623577.html
You can learn more at https://university.atlassian.com. Check it out, it's a great resource. However there are tools to help automate this process but to start with - create and excel sheet/Checklist to keep you on track.
