Using the following page, How do I do a signup feature and eliminate login element
I only want to stay with the Use OAuth Login
Hi Tayebwa,
I am Sanyukta from miniOrange.
An option for "Auto-Redirection" is available under "Sign-in settings" in OAuth Single Sign On. You are required to enable that option which in turn will disable your local login & your end-users will be forced to login through the OAuth provider.
If you have any other concerns, you can reach out to us & raise a ticket here.
Sanyukta
