how to add associater or followers in a Jira Issue. For example, there are two fields one is assignee and reporter. If I want to add more persons that can contribute into particular issue then how can I add those persons, I did not found any field like associaters/followers in JIRA Issue tracker.
Hey Jignasha,
you could add a "single user picker" or "multi user picker" custom field and name it participants f.e.
There you could set associated user or followers-like.
Administration -> custom fields -> add custom field (Standard for single user and advanced for multiple) and add it to your wanted screen.
BR
Simon
Thanks, it worked for me like a charm...
Hello Simon, It works. Thanks and highly appreciate for a quick help.
Though I did it at issue level, I did not find the custom field option at project level or globally thru out every project. I want to add it globally.
To add it globally you should set the custom field on the "Default Screen".
