how to add "create another" checkbox to create issue screen
Dmitriy Ibatulin May 21, 2018
Hi, i didn't see this checkbox in create issue screen. How to add this checkbox to jira version 7.3.7?
Yogesh Mude
May 21, 2018
Hi @Dmitriy Ibatulin,
This checkbox by default available on creates issue screen.
If you are crating issue from any other screen/page then it will not show you this create another checkbox.
If you are creating an issue from dashboard then you will be able to see this option.
CPU_USAGE2.pngunfortunately i didn't see this checkbox when try to create issue from dashboard. That's why i ask this question
Yogesh Mude
May 21, 2018
Please try to crate issue from system dashboard or press g+d it will redirect you to the dashboard then only it will show you create another checkbox while creating an issue.
I think you are not trying from dashboard hence you are not able to see it..
the same thing
Alexey Matveev
May 21, 2018
First, you need to create a custom field of the Checkboxes type. Then when you add the field to the create issue screen, you will have a checkbox in the screen.
but this field will be without "create another" functionality
