Their is a existing Project Board already which as all the categories like Backlog, Issues, Reports, Components etc. But Roadmap field is Missining.
I need to add this option (Roadmap) in order to create Epic's and Tasks.
Can anyone advise how to add the Roadmap field for the existing project Board
Hi @Sowmya V
Are you looking to use the simple roadmap feature? A Jira admin would be able to enable it for your project board but as Jack mentioned, Advanced Roadmaps is a great tool to use for creating roadmaps.
Disclaimer: I do not use Advanced Roadmaps
I see you are on Premium so you have Advanced Roadmaps. Roadmaps are created under the "Plans" menu item. Details of how to get started are here - where-do-i-find-advanced-roadmaps . There are a number of articles here that will help guide you through the process.
