how to connect jira issues with github?
priyabhath
January 23, 2024
Hi, I have a Project board with issues in github. I need to stop using github project board and want start working on Jira project board. to do it i need to import my issues on github to jira.
Is it possible to import all the issues in github to Jira?
What is the easiest way to do it?
and also when i create an issue in jira how can i connect it with Github?
Dhiren Notani_Exalate_
January 30, 2024
Hi @priyabhath ,
Thanks for asking your question here on the community.
I am Dhiren, one of the Solutions Engineer working at Exalate.
Exalate is a completely decentralized and fully bi-directional issue sync solution. You can synchronize GitHub Issues with Jira Issues and can also use the Bulk Exalate functionality to sync historical issues as well.
The tool provides you a scripting interface through which you can choose what information will sync within the issue and you can also map fields like Assignee, Status, Title, Comments, Labels etc.
Do let me know if you want to know more about how the solution works!
Thanks, Dhiren
Diana_Architect_ZigiWave
@priyabhath hi there. If you're still looking for a way to make the Jira GitHub integration and sync data, feel free to check out ZigiOps at the Atlassian marketplace. It's a fully no-code integration solution that is 100 % secure and connects the two bi-directionally in a couple of minutes. ZigiOps is flexible and customizable so it can fit various use cases. Feel free to give it a try via the free trial option.
Diana
Rebekka Heilmann (viadee)
Hi @priyabhath  and welcome to the Community!
Have a link at this thread: What's the best way to migrate Github issues into ... (atlassian.com)
Generally speaking, you can import issues by csv or by API. It depends on what format you can get from github.
FREE
