how to convert invalid_fields variable in python script to java?
Bharadwaj Jannu
March 11, 2013
Hi
I'm converting a python script(which uses invalid_fields variable) to java language.
e.g: I want to convert
invalid_fields['priority'] = u'Please select proper Priority.'
please provide how it is represented in java.
JamieA
March 20, 2013
You need to return an ErrorCollection, see com.atlassian.jira.util.ErrorCollection#addError(String field, String message).
Bharadwaj Jannu
March 12, 2013
The invalid_fileds variable is used in python script which acts as inline script for jss plugin.
So please consider as a related question to atlassian software.
